Menu and Rating stars are vertical instead of horizontal
Discussion in 'GeoCraft WordPress Theme' started by mtnewsy, Mar 12, 2013.
  1. mtnewsy
    mtnewsy Guest
    Thanks very much for the awesome template! I've been using Geocraft for a couple of weeks. I've been mosying along, building it up, and the menu and the stars for the ratings were displaying just fine, but now they display vertically instead of horizontally. Please see the attached screenshots.
    These are the last few things I did before this happened:
    1) I updated the Geocraft template to the newest version
    2) I uploaded a new logo
    3) I uploaded a favicon
    4) I refreshed the page and noticed the problem.
    Also, this issue happens in Internet Explorer, it displays okay in Chrome.
    Any ideas on what's causing the problem and how to fix it?
    Thanks in advance for your time.
    IE7 is an outdated browser which does not supports latest HTML tags. We have developed the theme keeping in mind all the latest web design principles and IE7 might not be compatible with it.
  3. mtnewsy
    mtnewsy Guest
    Thanks for you reply. I'm not using IE7, I'm using IE10 on Windows 8. IE10 is the latest browser. Like I said, it worked fine up before I uploaded the pictures. What are you suggestions for fixing the problem?
  4. Harmeet
    Harmeet Support Staff
    It seems that any plugin is creating the problem in the theme, So deactivate all the plugin to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s). If then also it doesn't solve your problem send the link of your website. we will check the issue.
