Menu bar on footer setting
Discussion in 'Squirrel WordPress Theme' started by headborough, Jan 1, 2014.
  1. headborough
    headborough New Member
    Hi there
    I am using squirrel pro and am wanting to put in a second navigation bar along the bottom of the webpage on the footer bar (footer text area not the footer widget area). Is this possible? Thank u in advance.
    But the possible solution is, to add "Custom Menu" widget in the Footer Widget Area of the Theme.
