On the homepage, the menu looks and acts like it should. But when you click through to an inside page, the alignment is disrupted. I've included screenshots, and you can see the effect on http://edandrea.com The first one shows the home page, the second one shows an iside page.
Hello, Your browser is at zoom 90%. Please set it to default 100%. Site will look normal. Thanks & Regards Nitesh Raghuwanshi
Hello, For alignment issue Download updated version of theme from your members area and upload it, This will solve your issue. Login here: http://inkthemes.com/members/member/index and for changes, Please check the changelog.php file of the theme. Changelog = Version: 1.1.4 = 1. Menu alignment issuefixed. = Version: 1.1.3 = 1. Lead capture form captcha on/off option added. = Version: 1.1.2 = 1. Select Option added in lead capture. 2. Dropdown feature added to lead capture form fields. 3. Lead capture form captcha changed. Thanks & Regards Gourav Shrivastava
Changing the zoom did not resolve the problem, but the new updated theme did solve it. Thank you for the update. Cheers, Ed
