Menu Color
Discussion in 'Photomaker WordPress Theme' started by tripperking, Apr 19, 2016.
  1. tripperking
    tripperking Member
    I have almost completely altered the color - But the current page highlight apears orange - How do I control the color?
    http://photos.phototours.vegas/
    Could you please share some edited screenshot so that we can assist you accordingly?
  3. tripperking
    tripperking Member
    See attached - The hover over color is off
    Below is the code for that..
    #menu li.current-menu-item a, #menu li.current_page_item a {
        background-color: #fe00a8;
  5. tripperking
    tripperking Member
    That didnt work same color - the pink and purple are making orange
    smith likes this.
  6. priya
    You can change color code in above CSS code as per your requirement.
  7. tripperking
    tripperking Member
    its not working consistently - all of the links on the site on "Hover" turn orange - The active page on some things turns gray after I changed the code to test just now.
    Also only some of the menu words turn green and then only in certain browsers, again not consistent below are all the current codes in the custom css area:
    .tf_content h1 a {
    color: #84fe2f;}
    .ddsmoothmenu ul li a:link{
    color: #84fe2f !important;}
    .content-bar h1.page_title {
    margin-top: 36px !important;
    background-color: #8c8984;
  8. priya
    Would you please try below code and check the result after that.
    .ddsmoothmenu ul li a:hover, #menu li.current-menu-item a, #menu li.current_page_item a {
  9. tripperking
    tripperking Member
    This is what I have now:
    .tf_content h1 a {
    color: #84fe2f;}
    and it still is orange on hover On some pages -it is inconsistent - also some pages have green font text and others white
  10. tripperking
    tripperking Member
    In Chrome - No green fonts
  11. tripperking
    tripperking Member
    Chrome on Different page
  12. tripperking
    tripperking Member
    Firefox same page
  13. tripperking
    tripperking Member
    Internet explorer
  14. priya
    Would you please send us your dashboard details at [email protected] along with this thread link so that I can figure out the issue and will do it for you..?
  15. priya
    Hello, I have resolved your issue...
    Kindly check your site..
