Menu element question
Discussion in 'BizWay WordPress Theme' started by karibou, Nov 12, 2012.
  1. karibou
    karibou New Member
    Hi, Iʻm wondering if, on the menu bar, there is a way to make a menu selection clickable so the sub-menu items drop down without it being linked to a page.
    Example: On the menu bar it says ʻMoviesʻ When you click it. it does not point to a page, it only causes the drop-down menu to show so the 3 below are page links. Movie is not a page, only a menu element for a drop down box.
    Only ʻComedy, Documentaries and Drama are pages. Does this make sense?
    Ex:
    Music
    - Comedy
    - Documentaries
    - Drama
    Sorry to explain it so badly, Iʻm not sure of the terms.
    Thanks!
    If this isn't something you're able to do then you would need to hire a developer for this.
    Take care.
