Menu Issue
Discussion in 'Traffica WordPress Theme' started by spoonboy90, Feb 4, 2014.
  1. spoonboy90
    spoonboy90 Active Member
    I have an open thread that was originally answerd but wasn't sure if I just asked on it it would get seen so i've started a new one!
    I was given this code to remove the gaps between the menu items (above image):
     #menu .ddsmoothmenu li {
    display: table-cell;
    which worked ok in all browsers until I added submenus, now Firefox & Opera are having issues
    In Firefox it's causing the menu to show up to far to the left
    and in opera to near to the top
    So is there another way to remove the gaps between the menu items or is there a simple fix for the browser issues please
  3. spoonboy90
    http://currant.i1024.co.uk/
    if I remove the above css the menu behaves normaly but there are gaps which i need to remove!
  4. Gourav
    For Firefox browser
    Paste this code in Custom CSS
    @-moz-document url-prefix() {
    #menu .ddsmoothmenu li ul{
    margin-left:49px;
    Adjust its value as per your requirements.
    For more info, please check the link given below
    http://www.conditional-css.com/usage
    Gourav Shrivastava
  5. spoonboy90
    Thanks Gourav but that works ok for the first dropdown menu but now other drop down menus are added its not a robust fix.
    Is there no other way to remove the gaps rather than the 'table-cell'
  6. spoonboy90
    Unlikely but should anyone else be interested in a solution to this problem i used the following css to resolve my issue
    /* Firefox Menu Fix */
    display: inline-block;
    margin-left: -2px;
    margin-right: -2px;
