Can not remove menu: Business Grow Front Page menu. I have created main menu and I tried to remove the default menu, however, It won't let me remove it.
Hello, Did you select the display location of the menu? If not then go to (Dashboard->Appearence->Menus) and select the Front Page Menu, just follow the attached screenshot. Hope this helps...! Thanks & Regards, Akbar InkThemes.com
Hi Akbar, I have selected the front page menu. My questions is about deleting the extra menu, which is Businessgro theme front menu. I did tried to delete the menu, however, it does not get deleted. Login credentials sent vial email. Thank you!
Hi, I have replied you in this regard on your email. Please check your e-mail and let me know. Thanks & Regards! Akbar InkThemes.com
