Greetings! I. LOVE. THIS. THEME! Foogo is quite impressive. I am, however, having an issue with the top nav bar: depending on which page you're on, the other menu labels aren't visible. The non-selected nav bar headings (to the right of the logo) are invisible until you hover your mouse over them. When you do hover, you can see dummy pages I created. [When on the Home page, the invisible nav bar headings are in RED.] Here is some custom CSS that I added ... taken from some other forum inquiries. There may be some conflicts that I've unknowingly created. #header .header-overlay { background-color: rgba(255, 255, 255, 0); } .top-header { background: white !important; } .fbtn.top-button { background-color: #aa0000 !important; webkit-box-shadow: 0 3px 0 #971b1b; -moz-box-shadow: 0 3px 0 #971b1b; box-shadow: 0 3px 0 #aa0000; } .building-btn a { background: #aa0000 !important; box-shadow: 0 3px 0 #3A3B37 !important; } I'll send admin access via email if you need that, too. It will be labeled "MERGE" in the Subject line. Thanks for your help. Glory
Hello, Glory.. Greetings from InkThemes! Thanks for the details Glory.. We will get back to you soon.. Thanks & Regards! Priyanka InkThemes.com
Hello Glory, Have done the changes for this issue... Kindly check your site... Thanks & Regards! Priyanka InkThemes.com
Priyanka, Strangely, I'm not seeing any changes. All menu options -- with the exception of the page selected (in this case, the Home page) -- are invisible unless hovering the mouse over the location of the nav bar where the other pages should be. Are you seeing the entire nav bar when you're on the Home page? This is what I see: Thanks, Glory
Hello Glory.. I have replied you at http://www.inkthemes.com/community/...-logo-to-create-more-space-for-nav-bar.20012/ link... Kindly check above link.. Thanks & Regards! Priyanka InkThemes.com
Priyanka ... Perfect! Would you mind telling me where the changes were made? ... and the code you used? I'd like to learn from this. Thank you! Glory
Sure Glory.. I just added below code in styling option of your dashboard Code: .sf-menu a { color: blue; } Thanks & Regards! Priyanka InkThemes.com
