Menu not working in mobile view
Discussion in 'BlackBird WordPress Theme' started by lyubo, Dec 25, 2015.
  1. lyubo
    lyubo Guest
    Hello Gigov,
    You are kindly suggested to reinstall the latest version of the theme from the members area.
    Here are the steps of doing so, please have a look.
    Download the BlackBird theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder blackbirdtheme like blackbirdtheme_new,
    Again, you would need to create a zip file of that renamed folder (say: blackbirdtheme_new.zip),
    Then, activate your theme,
  3. lyubo
    lyubo Guest
    Hello Priyanka,
    thank you for the quick response. I did it as you said but it didn't resolve the problem.
    The menu still didn't work in the mobile version. I have a multisite and it was customized (hard coded) through
    your support: http://www.inkthemes.com/community/...-pages-navigation-menu-at-mobile-phones.5294/
    The second problem ist that I have a language (flags) switcher at my site. As I tried the new theme version the flags disappear and
    I had to switsch to the old version.
    Lyubo
    OK Lyubo,
    Please send us your dashboard credentials at [email protected] along with this thread link so that we can figure out the issue and able to resolve that..
  5. lyubo
    lyubo Guest
    Thank you Priya,
    I did it.
    Regards, Lyubo
  6. priya
    Thanks for the details...
  7. priya
    You would be glad to know that your issue has been resolved..
    Kindly check.
  8. lyubo
    lyubo Guest
    Thank you! Great and quick support. Solved at the next day!
  9. priya
    You're welcome..
