Menu problem - not function while in a page
Discussion in 'StartPoint Business One Page WordPress Theme' started by effyeweb, Sep 3, 2014.
  1. effyeweb
    effyeweb Member
  2. Yogesh
    Yogesh Guest
    Make new footer menus and give in hyper-reference give whole address like following.
    For Home --> http://www.en.tongkengengbeauty.com/#top
    That will resolve your issue.
    Yogesh Bhade
  3. effyeweb
    effyeweb Member
    ok, Thank you....:)
  4. effyeweb
    effyeweb Member
    later i have another problem
    http://www.en.tongkengengbeauty.com/sample-page/
    the custom menu create with above instruction in footer did bring to the correct page but not in RIGHT POSITION.... please try
    IT do not slide to right position while using footer custom menu
  5. Yogesh
    Yogesh Guest
    Slide to right position functionality is built with only main menu, not with footer menu.
    So you can use different menus in footer not same as main menu.
    Yogesh Bhade
  6. effyeweb
    effyeweb Member
  7. effyeweb
    effyeweb Member
