Hello, I have a simple problem with the menu. I just want that when a voice of my menu has some sub-voices, it doesn't have a link. Also a link with href="#" would be just fine. Below an example: Thank you very much, Matteo
I would like to know the same thing. I wanted to use multiple Galleries but not have a link in the main menu title as well. Interested to know if this can be done or not. Thanks.
@matteo21 check this answer given to what I believe is the same issue: http://www.inkthemes.com/community/threads/menu-element-question.374/
Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry. If this isn't something you're able to do then you would need to hire a developer for this. Take care.
