1. Can you change the text-style of the menu headings (i.e. parent pages)? I was able to change the size and font using custom css, but nothing more. Specifically, I wanted to bold the text. 2. Is it possible to change the color of the drop-down menus? I managed to change the hover color, but that is all. Thanks.
Go to Js > custom.js present in your theme directory and remove the code given below Code: //Font Replace Cufon.replace('#menu ul li a',{hover: true})('#colRight h2')('.reply',{hover:true})('h1')('h2')('h3')('h4')('h5')('h6'); Sending image for reference Now, Paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS Code: #menu li.current-menu-item a{ font-family:Your Font Type; font-weight:bold; font-size:20px; } #menu li a { font-family:Your Font Type; font-weight:bold; font-size:17px; } #menu .ddsmoothmenu li li a{ color:red!important; }
Thanks. That fixed my first question, but I wasn't clear enough about the second. That code changed the font color of the drop down menu, but I actually wanted to change the color of the menu itself. I managed to do that by changing this (color:red!important) to this (background:red!important) but now the hover color isn't working. Is it possible to change the menu color and still use a hover color? Thanks again.
Sorry, one more question. That code made both the menu headings (parent pages) and menu items (sub-pages) bold. Is it possible to only bold the menu headings?
Hello, Paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS Code: #menu .ddsmoothmenu li li a:hover{ background:blue!important; } #menu li a{ font-weight:normal; }
Thanks again. The menu color worked, but unfortunately it has now reverted both the menu headings (parent pages) and menu items (sub-pages) to a normal rate. Is it not possible to have have different weighting for these the heading and items in a menu?
Paste the following code in your Custom CSS (Appearance -> Theme Options -> Styling Options -> Custom CSS) Code: #menu .ddsmoothmenu li li a { font-weight:normal; } instead of Code: #menu li a{ font-weight:normal; } This will solve your issue.
