Menu repair
Discussion in 'Cloriato WordPress Theme' started by nfelectrical, May 28, 2013.
  1. nfelectrical
    nfelectrical New Member
    Hi, can you tell me how to repair my menu bar drop down box boxes
    Regards
    For creating dropdown all you have to do is add new pages name them (for eg. submenu 1, submenu 2)then select Menus option (Appearance > Menus) and follow instruction given in image
    NOTE:Main menu option and Menu Name both should sharing the same text.
  3. nfelectrical
  4. Piyush
    We have visited your website the problem is occurring due to any one of the plugin you are using,
    Deactivate all plugins one by one and checkout which plugin creating this problem.
  5. nfelectrical
    Hi, I have been through all the pugins and I still have the problem??
  6. Piyush
  7. nfelectrical
    Will you please look again!... Properly. The drop down menu under 'ELECTRICAL' and the menu under 'ACCESS/SECURITY' are not visually correct!
    http://www.nfelectrical.co.uk
    Thank you
  8. Nitesh
    I have checked your site again but not found such issue.
    I know you are facing this issue but don't know why it is not occurring at my side.
    Check image for reference.
    Please do let me know if in any particular browser you are getting this issue.
    And also check your site on any other system too.
    I hope it will work.
