menu's and layout are gone
Discussion in 'Blackriders WordPress Theme' started by caservices, Aug 11, 2017.
  1. caservices
    caservices New Member
    i just installed this theme but all my menu's and layout is totaly different then on the demo.
    and i don't know how i can fix this.
    hope somebody can help me.
    best regards
    Sebastian Garcia
  2. akbar92
    First of all, you need to create a new menu, go to (Dashboard->Appearence->Menus) and click on the Create A New Menu button, just follow the screenshot: https://screenpresso.com/=NMQ8g
    Then select the main menu check box to make a menu as the main menu, just look at the screenshot: https://screenpresso.com/=4yhXf
    And then set the order of pages.
    Hope you find above information helpful.
    Thanks & Regards,
    Akbar
  3. caservices
    thanks, I now have the good layout, but I think I'm still sleeping but how do I change the tekst in the page or add things but I can't find them in the WP structure. even the first page I can't find.
    my website is for now located at www.sfgarcia.nl
    thanks for your help
    Regards
    Sebastian Garcia
  4. akbar92
    To change or add the text in pages, go to (Dashboard->Pages->All Pages) and click the edit button to start editing, just follow the attached screenshot: https://screenpresso.com/=URf1g
    Hope this helps...!
    Akbar
  5. caservices
    Hello
    Thanks, that works, but where can I find the settings and tekst options for the contact field?
    Because now there is standing
    Colorway Lite is also available for Download at WordPress.org
    And that I want to change, and when i make more pages and put them in a menu together I don't get a dropdown menu so I think I do something wrong.
    Hope you can help me once again.
    Best regards
    Sebastian Garcia
  6. akbar92
    I would like to inform you that you can't edit our default contact page template.
    But, I would like to recommend below plugin to create your own contact form.
    1. https://wordpress.org/plugins/contact-form-7/
    And you can set the order of the menu and create drop-down menu via your dashboard, go to (Dashboard->Appearence->Menus), just follow the attached screenshot.
    Hope this helps...!
    Akbar
