Hi, I'm trying to understand why my meta description in SEO options is not being used by the search engines. I have inserted the following: Carpet Cleaning services Doncaster. Fantastic results every time. High quality carpet cleaning services in Doncaster. 01302 27210. Text 07849 654413. This comes up when I seach for the web site title: Carpet Cleaning Doncaster . Fantastic results at local Doncaster prices. Call Merlin clean for Carpet Cleaning Doncaster. 01302 272101. This does not appear to be happening on the other sites I have made with this theme. The web site is: https://www.merlinclean.co.uk/ Thank you.
Hello Paul, I have also checked your site and found this: https://screenpresso.com/=GzUwg It seems that is related to your server cache, Kindly check if you are using any cache plugin on your site. If so then, clear the cache and check your site again. Warm Regards! Naveen Kolhe InkThemes.com
