Hey guys, I need a bit of assistance here. I have just discovered to my horror that the figero theme is not functioning properly. Or to put it another way the code on my theme is incomplete. I seem to be missing my meta description. Although you offer a place holder in the theme options for me to enter a meta description my description does not show when I view the source. My meta keywords do though. I also looked at the php code in the header and found that there is no meta description there either you have meta name= keywords content= and meta Author but no meta description? Please fix or can you show me how to access the html source code so I can fix it myself.
Hello, I think you are using any seo plugin which override the theme default meta description. Uninstall that seo plugin this will solve your issue.
Hi Piyush I tried that and it did not work! And now I have more issues with this theme! For some reason I cannot find/or access my blog categories. When I click the links to view the content in my categories I get this: I need to have these problems fixed please I paid a lot of money for this theme and to be honest I think it is not what you portray it to be I have had nothing but problems since I purchased it.
Hello, Please provide the following information listed below. Thread Link: Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] I will check your issue. Thanks & Regards Gourav Shrivastava
Hello, Issue resolved, Please check your website link. Note:- Please never share your dashboard details on open forum. Thanks & Regards Gourav Shrivastava
Hi Gourav thanks for the help. Yeah I knew I had made a mistake when I posted those details thanks for covering up my mistake. Just out of interest what was the problem and how can I avoid it it and rectify it next time?
