Missing Slider Image and Slider Speed
Discussion in 'Elite Pro WordPress Theme' started by bizzyboy, Dec 9, 2014.
  1. bizzyboy
    bizzyboy Member
    Hi
    About 1 year ago I setup a website using Elite pro and at the time I had a problem which was eventually sorted by support logging into my Website.
    Here is the support thread from last year:
    http://www.inkthemes.com/community/threads/widget-conflict-with-home-page-slider.9068/
    I have setup another website and I have a 'similar' problem in that I cannot see the Slide Image and the text to the right of the image.
    For example here is a website that uses the them and how the website should look:
    whichgoldbackedira(dot)com
    And here is the website that does not show the Slider:
    goldsilveriraplans(dot)com
    And I also noticed when I check the Theme Options and then Slider Settings that there is no input box for a Slider Speed. I have disabled each of the Plugins to make sure it is not a Plugin issue but disabling the Plugins does not solve the problem.
    Any help appreciated.
    Paul
  2. Yogesh
    Yogesh Guest
    Hello Paul,
    .flexslider .slides > li {
    display: block;
    It will resolve your issue.
    Yogesh Bhade
  3. bizzyboy
    bizzyboy Member
    Great, that works. Many thanks.
