this is the error message I get: Installing Theme from uploaded file: dentalclinicwordpresstheme.zip Unpacking the package… Installing the theme… The package could not be installed. The theme is missing the style.css stylesheet. Theme install failed.
Hi, Greetings from InkThemes, It would be our pleasure to serve you. It seems that you have not extracted the folder properly. Kindly extract the .zip file of the theme. There you will find the theme documents, data, PSD files and other files of your resource. If possible create a .zip file properly or directly copy the theme folders/files to the themes folder. Hope it will resolve your issue Thanks & Regards! Nitin InkThemes.com
