mobile device footer code help needed
Discussion in 'ButterBelly WordPress Theme' started by tracykperry, Mar 2, 2016.
  1. tracykperry
    tracykperry Member
    I've got my desktop site setup the way I like but the footer is not correct on a mobile device.
    The site is www.sagewellnesspartners.com
    and here are screenshots of the mobile (I don't want turquoise - I want the color the same as the non mobile site.)
    non mobile footer
    .footer .footer_widget h4 {
        color: white;
  3. tracykperry
    tracykperry Member
    I added this and it did not work.
    Screenshot below
    Try below code for once and check after that..
    .footer .footer_widget .searchform input[type="text"] {
        color: white;
        background: url(images/footer_searchbg-black.png) left no-repeat !important;
