Two questions: 1. how would I remove the phone number so it does not display on the mobile page? 2. is there a way to force the menu to be stacked, two lines? Or maybe some way to stack the name of the pages themselves? ie. Page One instead of Page One
Ok I figured out the first question... if you are curious I used this: .call-us { display: none; } Still wondering if I can stack the menu so it is on two lines in the header.
Hello, Greeting from InkThemes, Could you please send me the screenshot of the area where you want these changes to be done. I will provide the solution for this. Regards, Akbar InkThemes.com
I need the menu items to be cleanly broken up. So forcing a line break after "mixes" so Breadings & Batters is on the second line no matter the display size.
Hello, Greeting from InkThemes, Will you please allow us to check your website dashboard for once? Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will do the needful. Regards, Akbar InkThemes.com
Hello Joe, Greeting from InkThemes, I have aligned the menu options. Kindly check them once. Inform us if you have any issues, we will be happy to help you. Regards, Akbar InkThemes.com
