mobile homepage
Discussion in 'One Page Pro WordPress Theme' started by mdpbklyn, Oct 3, 2017.
  1. mdpbklyn
    mdpbklyn New Member
    How do I make the mobile homepage be the desktop page and not the blog page?
  2. akbar92
    Will you please elaborate your query a bit more with the help of some edited screenshots of the concerned areas of your site.
    Akbar
  3. mdpbklyn
    mdpbklyn New Member
    merlehoffman.com.jpg mobile_merlehoffman.com.jpg I am getting the blog page (mobile_merlehoffman.com) as the homepage on mobile devices and want the desktop version homepage to show instead. I can find no way to do this. Is this something that I am missing?
  4. akbar92
    I would like to inform you that, the theme is built to keep responsiveness in mind, that's why it has a different homepage layout on mobile and desktop as well.
    If mobile homepage will display as a desktop homepage, then it will not look soo good.
    Hope you understand this.
    Akbar
  5. mdpbklyn
    mdpbklyn New Member
    Guess I will be changing themes.....
  6. akbar92
    Maybe one of your plugins is conflicting in your site because on our theme live demo there is no such error.
    Kindly have a look at our theme demo: https://www.inkthemes.com/previews/?demo_id=505
    You are requested to deactivate all of your plugins once and check your site's again,
    Then activate one by one your plugins checking result on each activation,
    Hope this will let you figure out messing up plugin.
    Warm Regards!
    Akbar
