Mobile Menu dropdown doesn't work
Discussion in 'GoldenEagle WordPress Theme' started by casesolutions, May 2, 2016.
  1. casesolutions
    casesolutions New Member
    I tried searching but didn't see this issue. I have a site I setup and never realized until today, and the home page dropdown on the mobile version doesn't work. When clicked on the demo, a dropdown appears and all pages are displayed. However, on my site, it doesn't work when clicked, nothing happens.
    Thank you.
    www.caseweb.info/_FPlace1
    I am unable to access your site...
  3. casesolutions
    Hello Mike,
    I have checked your site and would like to tell you that you are using 1.1.4 version of the theme whereas 1.1.5 is available in the members area..
    So if you haven't customized source code of the theme, you are kindly suggested to reinstall the latest version of the theme from the members area.
    Download the GoldenEagle theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder goldeneagle like goldeneagle_new,
    Again, you would need to create a zip file of that renamed folder (say: goldeneagle_new.zip),
    Then, activate your theme,
    smith likes this.
