Mobile menu not visible
Discussion in 'ColorWay WordPress Theme' started by dmedia, Jul 19, 2015.
  1. dmedia
    dmedia Member
    Hello: Love this theme. However, the mobile menu for my site is not displaying on smart phones: http://fwvetspecialty.com
    (I checked on iPhone and Samsung.)
    Is there some custom CSS that will fix this? Thank you!
  2. praveen
    praveen Support Staff
    It seems that some of the plugin used in your website WordPress dashboard conflict with the functionality of the menu.
    Kindly deactivate plugin and check.
    If the issue still persists, send us your website WordPress login details at [email protected] along with the thread link.
    Praveen
  3. dmedia
    dmedia Member
    I deactivated plugins one by one. I figured out it was the plugin Simple Custom CSS. When I removed that plugin, the menu appeared. So I took the custom CSS I had saved inside that plugin, and instead inserted it into the Custom CSS within the Colorway Theme Options. Then the mobile menu disappeared again. So it must be some CSS in the custom CSS but I can't figure out what's doing it. Can you take another look?
  4. dmedia
    dmedia Member
    I figured out the CSS the theme doesn't like. It's this line:
    .container {
    margin-top:25px;
    In the original CSS that line is:
    .container {
    margin-top:55px;
    I had changed it to 25px instead of 55px to make the top of the container (page background) move up higher. Since that messed up the mobile menu, is there another way to achieve this? I would like less space from the top of the browser to where the page starts. Trying to make it not so far down.
    Thanks for your help!
  5. praveen
    Please send us your website WordPress login details at [email protected] along with the thread link.
    Also, provide us some edited screenshot about the changes that your want in mobile view.
    Praveen
