dear team, I have just noticed that the mobile navigation issue I am having with my Infoway based site goes away when I disable the W3 Total Cache Pluggin. Have you seen this issue before and if so can you advise of the W3 Total Cache setting that causes the problem? Best regards, Pat.
Hello, Could you please specify us the issue with the help of screenshot image when the W3 Total Cache plugin installed.
A screenshot won't really help, Basically what happens is the mobile navigation menu is disabled when the pluggin is active with multiple settings applied. When this happend and you select they"mobile pages menu" on mobile it simply reloads the existing pages rather than dropping down the site menu. Best regards, Pat.
