Mobile Navigation and font size
Discussion in 'Blackriders WordPress Theme' started by peterv, Nov 27, 2013.
  1. peterv
    peterv New Member
    • reply via.JPG How to increase font size ONLY for mobile version.
    • How to customize site in this them for mobile? Do you have any documentation for that? Its showing my all 45 pages in mobile Menu (main and sub pages). If clicked on mobile navigation button in mobile, its toooooo big to deal with. Can I have only some pages to show up in mobile navigation? Currently I have removed all the pages from Product submenu.
    • I have 2 phone #s added in header successfully on desktop version they are ok but in mobile version, Logo + 2 tap to call buttons takes 3/4th of screen. how to change the Tap to call buttons to reduce their width or show them side by side in mobile to save some screen space but i don't want them side by side in desktop version?
    • Kindly visit this link here close to bottom of the page. "Reply via" has 3 radio buttons Phone Fax Mail
      for but they get merged together (pic attached). Please advice how to fix them.
    • Where to add conversion tracking code in your lead capture form OR how to auto redirect to different page, once lead is captured.
    Thanks for your help in advance.
    Peter
    Do let us know your website link.
  3. peterv
    peterv New Member
    Hi Gourav,
    website address is here
    thanks for your inputs in advance.
    rgds
    Peter
  4. Piyush
    1. For your first issue,
    paste the following code in your Custom CSS
    a {
    font-size: 12px ! important;
    p{
    div{
    span {
    .signupform-header h4 {
    font-size: 14px ! important;
    You can change the value of font size as per your requirement.
    2. For your second issue,
    3. For your third issue,
    .call-us a.btn {
    background-size: 100% 100%;
    margin-left: 0px;
    float: left;
    width: 45%;
    padding-right: 14px;
    4. For your fourth issue,
    input[type=radio ]:not(old) + label {
    margin-left: 2px ! important;
    input[type=radio ]:not(old) {
    opacity: 1 ! important;
    5. Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry.
  5. peterv
    peterv New Member
    Thanks for your inputs. all works fine.
    Other then point #5.
    Sorry to say can't be pleased with the response. As you can see, I already hired 2 freelancers to get some work done. can't keep doing that. This theme is focused on Lead Capture but you can't help me setting up conversion tracking code on success page? doesn't sound right! It's premium there. Kindly help!!!!!!!
    rgds
    Peter
  6. Gourav
