Mobile Navigation Menu
Discussion in 'BlackBird WordPress Theme' started by eurobiketrans, Jan 17, 2014.
  1. eurobiketrans
    eurobiketrans New Member
    Hello Gourav can you help please, I'm new to website building, and I am using the Blackbird pro Theme. In the section Appearance>Theme Options>General Settings is a box called Mobile Naviogation Menu. It asked for text to be added. Can you tell me what to put in this box please? Many thanks Tony
  2. eurobiketrans
    Dear Gourav, can you answer one other similar question please. In the Appearance>Theme Options>SEO It says type in key words separated by commas, so does it matter if there is a gap between the words i.e. one,two,three or should it be one, two, three? Thanks for guidance Tony
    PLUS are the letters case sensitive please??
  3. Nitesh
    It doesn't make any difference to the search engines whether or not you put spaces after the commas.
    So either way is fine.
    And they're not case sensitive.
    Nitesh Raghuwanshi
  4. eurobiketrans
    Thanks Nitesh
    Tony
  5. eurobiketrans
  6. Piyush
    The default value of that section is "Pages Navigation Menu".
    If you want to change the text then put your text in that section it will display your text in Mobile Navigation Menu for mobile view
    else leave it blank it will display the default text.
    See the image given below for reference
    I hope it will help you.
