mobile not showing slider text
Discussion in 'Woodpecker WordPress Business Theme' started by sandradohn, Jan 18, 2016.
  1. sandradohn
    sandradohn Member
    Hi There, The text on the slider does not show up on mobile. I tested this on android and iphone. Please let me know how to correct this. The site is primestrategyinc.com
    Thanks, Sandra
    Hello Sandra,
    Let me tell you that we usually disable this feature for small devices due to responsiveness issues as on small device the text will become so small and will be not readable as well..
    But still if you want to get this in your site, we will do it for you...
    Do let me know what you think..
  3. sandradohn
    sandradohn Member
    Hi There, Thank you for your prompt reply. Yes, I would like the text on the slider to show on mobile for primestrategyinc.com Thanks, Sandra
    Hello Sandra,
    @media (max-width: 767px){
    .nivo-caption {
        visibility: visible;
        width: 100%;
        height: auto;
    .nivo-caption h1 {
        font-size: 20px;
    p.slide-para {
        font-size: 15px;
    .slide-button {
        font-size: 15px;
  5. sandradohn
    sandradohn Member
    That worked! Thanks, Sandra
