Mobile Phone
Discussion in 'BizWay WordPress Theme' started by sethloux, Feb 20, 2013.
  1. sethloux
    sethloux Guest
    Images and words get cut off viewing the website on a mobile phone. Any way to fix this so it does show the complete image and text?
    Please explain your problem with the help of screenshot and also share the link of your website, so that we can give you the exact solution.
  3. sethloux
    sethloux Guest
    I want to just disable the mobile site. How can I do this? Is there a code to input in to the styling sheet?
    Thanks!
  4. Gourav
    It is not possible to make Bizway theme non-responsive because it is implemented on 960 responsive grid system and if we try to make it non-responsive it will break the layout of the theme.
  5. sethloux
    sethloux Guest
    My point is most sites can be viewed now through cell phone without having to using the custom that you have built in. I need to disable it so it just goes to the regular site.,not a mobile theme. The mobile theme doesn't work. It cuts off my words and images when you go to it.
  6. Nitesh
    It is not possible to change complete framework the theme.
    Do let us know your website link. Screenshot of affected area.
    We will check and resolve your issue.
  7. sethloux
    sethloux Guest
    It's all the pages when loaded in mobile. It zooms in and won't let you out of the zoom and words and pictures are cut off.
  8. Nitesh
    Please do let us know your website link.
  9. sethloux
    sethloux Guest
    The site is www.steen.com. If you load it on any mobile phone, you will see what I mean. I know you are using responsive framework but I don't think it is necessary. I rather have the site load and the user just be able to zoom in and out. Please let me know a solution that will allow the site to work in a mobile environment because right now it doesn't display the complete image or text from the responsive framework.
  10. Nitesh
    Bizway non responsive theme sent through mail.
  11. sethloux
    sethloux Guest
    Hi. Thank you for sending me this but it still doesn't work. I need it to display like a normal website. If they have to zoom in to read it, I am fine with that.
  12. sethloux
    sethloux Guest
    Nitesh,
    Did you get my last post?
  13. Nitesh
    I have checked your site " www.steen.com"
    You have not uploaded non responsive theme. Please upload it and check. It will fulfill your requirement.
  14. sethloux
    sethloux Guest
    I have uploaded it to our test site. I can't upload it to the official site until I have it working.
  15. Piyush
  16. sethloux
    sethloux Guest
  17. Piyush
  18. sethloux
    sethloux Guest
    Please see attached images. This is loaded from my phone.
  19. sethloux
    sethloux Guest
    Do I need to start a new thread for this issue?
  20. Gourav
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
