mobile question
Discussion in 'Woodpecker WordPress Business Theme' started by sangermike, Nov 18, 2014.
  1. sangermike
    sangermike Member
    I saw a thread where the call button can be disabled on desktop only but still appears on mobile. Will it be possible to disable a top header image in mobile only but still appear on desktop view. I removed the top header image right now but i used the codes I saw in this forums too but would like to put it back if the previous question is possible.
    .top-wrapper {
    background: url(http://www.yubacitytowing.com/wp-content/uploads/2014/11/top-header.jpg);
    background-repeat: no-repeat;
    background-size: 100%;
  2. Yogesh
    Yogesh Guest
    Paste the code given below in Custom CSS section it will show you the best result, it will disable that image in that view where that image get cut.
    @media only screen and (max-width: 992px){
    .top-wrapper {
    background: none;
    It will resolve your issue.
    Yogesh Bhade
  3. sangermike
    sangermike Member
    Hi Yogesh. I tried the codes and it worked only for a certain point when minimizing my deskptop browser. While dragging it down to that size then pops back again while continuing dragging the browser smaller. On the tablet and smartphone the top-wrapper is still there. I tried adding codes with different resolutions or even the min-width but didn't get rid of the background.
  4. sangermike
    sangermike Member
    I also cleared cache and cookies off the other devices.
  5. Yogesh
    Yogesh Guest
    @media only screen and (max-width: 767px){
    .top-wrapper {
    background: none !important;
    .top-wrapper {
    Yogesh Bhade
  6. sangermike
    sangermike Member
    Hi Yogesh. I tried but it didn't work. :( Any suggestion? Thanks
  7. sangermike
    sangermike Member
    Yogesh, i got so frustrated I thought I'd start over and deleted both the logo and the top-header from the >Appearance>General Settings panel. After I did, there was another background image left. What should I do now :(
  8. Yogesh
    Yogesh Guest
  9. sangermike
    sangermike Member
    email sent. Please disregard last comment on the left over image. I hope you can figure out the mobile issue. Thanks!
  10. Yogesh
    Yogesh Guest
    Your given details are wrong. Please provide us right username and password of your dashboard via email.
    Yogesh Bhade
  11. sangermike
    sangermike Member
    email sent
  12. Yogesh
    Yogesh Guest
    We have fixed your issue. Please visit your site.
    Yogesh Bhade
  13. sangermike
    sangermike Member
    Yogesh, Thank you so much to your support team. I wish you'd share how you were able to fix it as it may be very useful for future use. You guys are very impressive.
  14. Yogesh
    Yogesh Guest
    Actually you haven't put the CSS code correctly in Custom CSS section, so that problem was occurring.
    You just forget a close bracket ( } ) so other CSS was not applying.
    Yogesh Bhade
  15. sangermike
    sangermike Member
    really? my bad. again, Thanks a lot!
