mobile responsiveness issues
Discussion in 'Dzonia WordPress Theme' started by pipsqueakcreative, May 21, 2013.
  1. pipsqueakcreative
    pipsqueakcreative New Member
    I am having some issues with the mobile version.
    1. My logo doesn't fit the mobile screen as it's bigger than the optimal settings listed in the theme customisation settings. Can this be resolved or do I have to make the logo smaller?
    2. I don't want the homepage fullwidth column to appear in mobile version.
    3. If the above items are not possible, I would just want my site to remain as it is on a pc, not responsive.
    4. I am having trouble with Slide 1 Caption description - I don't want any text in there and if i leave blank i get the default template text. I have Caption Headings, I just don't want to add a description. Slide 2 and 3 etc allow me to leave the field blank.
    1) For logo:
    Paste this code in Custom CSS
    .logo img {
    width: 100%;
    2) For fullwidth column:
    .fullwidth-col{
    display:none;
    4) Just add blank <p></p> in the description field.
    check image for reference.
  3. pipsqueakcreative
    Thank you. I have not been able to get the <p></p> code to work in the caption description. See image below. This is Slider 1.
  4. Nitesh
    to remove heading and description.
    #slides .caption h2{display:none;}
    #slides .caption p{display:none;}
    to remove it completely.
    #slides .caption {display:none;}
