I saw in another thread to re-install the theme from the member's area and it should fix the problem. However, I made some changes to the front-page.php file, as well as custom CSS and I want to make sure all that stays in tact. can you look at the site for me and let me know what to do? Also, I have a video embedded that is set to auto play. On mobile it does not auto play, and the player appears to be cut off. I am not sure if this has anything to do with the alignment issue or not. site is palmcleaningsystems.com/tile-floor-cleaning-ppc
Hello, While updating theme changes done in php file (like:front-page.php) will lost. You can use child theme to save your changes. Download child theme attached and paste your front-page.php file in child theme directory and activate it. After that update your parent theme. For video set iframe width 100% and height auto. It will resize video according to screen size. <iframe width="100%" height="100%" src="//www.youtube.com/embed/miMQlt0y094" frameborder="0" allowfullscreen></iframe> Thanks & Regards Nitesh Raghuwanshi
