My website, http://surfcitysurfdog.com/ is not working correctly on mobile phones. I looks like this when I open it from my iPhone. Is there some sort of code I can add to make it show up correctly? Thank you!
Hello, I have checked your website. It seems that you have used some plugin to show your website in mobile view. I want to tell you that ColorWay Theme is a fully responsive theme and there is no need to use any plugin to show it in mobile view. So, kindly deactivate the plugin. I also find that you have used some plugin for menu in mobile view, please deactivate it also because we have already provided menu for the mobile view and it works perfectly. Do let me know if need further assistance. Thanks, Praveen
Hi! I'm having a similar issues on mobile: We have tried by restoring all theme settings to it's original state of the site, but the sidebar nav still doesn't show these menu items. Could you point us in the right direction or any clue to why this is happening? http://1up.fluidnrgclients.com
Hello, You are suggested to reinstall the theme and check after that.. Hope it will resolve your issue Thanks & Regards! Priyanka InkThemes.com
