Mobile View - Vertical Search Box
Discussion in 'GeoCraft WordPress Theme' started by rdeshazer, Jan 29, 2016.
  1. rdeshazer
    rdeshazer Member
    USA
    1. "Search Listing" should be "RED"
    2. "Search Listing" should be "CENTERED"
    3. Grey "Board" should extend to board search, location and search listing. needs to extend right more.
    Solutions are accordingly..
    1) "Search Listing" should be "RED"
    Please paste the code given below in Custom CSS field (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    #results ul li a {
        color: red;
    2) "Search Listing" should be "CENTERED"
    #results ul li a {
      text-align: center;
    3) Grey "Board" should extend to board search, location and search listing. needs to extend right more.
    Code is given below,
    .main_search {
        width: 100%;
        margin-right: 0;
        margin-left: 0;
    Hope it will resolve your issues...
  3. rdeshazer
    rdeshazer Member
    USA
    For number 2 the code did not work and the button is still a white color instead of red.
    Thx
    Try below code to make the text in center,
    input#search_for {
        text-align: center;
    And, for the button that is still a white color instead of red..
    Please provide us some edited screenshot of the concerned area so that we can assist you accordingly..
  5. rdeshazer
    rdeshazer Member
    USA
    My apologizes, my issue number was off, I will explain again.
    From a computer the "SEARCH LISTING" button is RED. In the mobile view the "SEARCH BUTTON" is white with a red boarder.
    1. In the mobile view the "SEARCH BUTTON" should be RED with WHITE text.
    2. In the mobile vertical view the entire search area is not aligned "CENTER" it is to far to the right.
    Please see attachment for both issues.
    thx
  6. priya
    For issue #1,
    We didn't get any issue with the search button as you have stated above.
    Kindly check the screenshot given below..
    For issue #2,
    Please paste the code given below in Custom CSS section of your dashboard.
    .main_search {
        margin-left: -8px;
  7. rdeshazer
    rdeshazer Member
    USA
    I added the code, however the Search Area function is still not centered and the button is round and white. I'm using an iphone, this is another image attached, even after clearing my cache its still coming up like the attachement.
  8. rdeshazer
    rdeshazer Member
    USA
    Anything?
  9. rdeshazer
    rdeshazer Member
    USA
    If you use an iphone, you will see that the "Search Listing" button is still white and oval shaped.
  10. rdeshazer
    rdeshazer Member
    USA
    1. ipadhor and ipadvert- are from an ipad mini tablet (the search listing button should be centered and access space grey area to the right should be reduce and even withe left side)
    2. iphonehorizontal and iphonevertical - are from an iphone 6
    So it seems that the search listing button in the mobile view is different than the search listing button from a computer browser.
    Please let me know.
  11. priya
    I have done changes in your site...and now your button looks good on iPhone screen...
    Kindly check your site...
  12. rdeshazer
    rdeshazer Member
    USA
    Fixed.
    Thx
