Modify "blue" color scheme
Discussion in 'BusinessGrow One Page WordPress Theme' started by natemjohnson, Aug 17, 2015.
  1. natemjohnson
    natemjohnson New Member
    When I select "blue" as the color scheme, the blue that is used seems a bit green-ish blue to me. I need to alter it slightly to match my logo and artwork. How can I adjust the blue that used when that scheme is selected? I think I'd like to use:
    #1919FF but may change it once I see it.
    Inkthemes.com
  3. natemjohnson
    ewgpartners.com
    Also, to be more specific, I am looking to modify the background color of the bar that reads "Learn More" as well as the boxes that are underneath the services circles.
    You can resolve it very easily, you need to paste below CSS code in the Custom CSS field located in Dashboard->Appearance->Theme Options->Styling Options->Custom CSS
    div#services {
        background-color: red;
    .rect_box {
    Note:- Please change the color according to your requirement.
    Hope you will resolve your issue :)
    Inkthemes.com
