Modify/Remove fields in Ink Appointment pluggin
Discussion in 'Smartbooking-Appointment Booking WordPress Theme.' started by battery1, Feb 11, 2016.
  1. battery1
    battery1 New Member
    Hi there
    Is it possible to remove the field 'service price' and modify the select service field to add options in the Ink Appointment plugin? I'd also like to modify the text on the submit button
    Website:www.getsolarbatteriesquotes.com.au
    Much appreciated
    Mike
    Hello Mike,
    It requires some source code customization in the theme...
    Would you please send us your dashboard credentials at [email protected] along with this thread link as well and we will do it for you..?
  3. battery1
    battery1 New Member
    Thanks Priya
    Email has been sent, let me know if any problems
    much appreciated
    Mike
    Thanks for the details Mike...
    Will get back to you soon...
  5. dmedia
    dmedia Member
    I would like to do a similar action. The first section with name, email & phone is fine. Then need 2 sections:
    1) Select Start Date
    Service: ____
    Date: ___ Time: ___
    (remove price)
    2) Select End Date
    Date: ___ Time: ___
    (no price)
    Instead of "Book Appointment" want it to say "Request Quote"
    This is for a shipping service. We need to know the customer's start date, time & location, then end date, time & location. We can't publish prices because it varies. When customers submit the booking form we want instant notification via email. Then we will call/email them with a price.
    Website: MDXfreight.com (you will need to login to view).
  6. priya
    We have successfully received your query at email and is being forwarded to our developers,
    As InkThemes has been receiving high volume of support requests our developers are busy at this moment, I will try to pull them on your issue and will get back to you with positive response ASAP.
    Hope you understand..
  7. dmedia
    dmedia Member
    Thank you, your themes are good and the support is even better! That is why I've continued with InkThemes --- paying monthly for many years. Appreciate your help!
  8. priya
    I would like to sincerely thank you for your appreciation, means a lot..
    We have already forwarded your issue to our developer team and they are working over it and will get back to you soon..
