More than one review per computer?
Discussion in 'GeoCraft WordPress Theme' started by coosconnection, Sep 30, 2016.
  1. coosconnection
    coosconnection New Member
    Anybody know how to enable more than one review per computer?
    As of now, with one review already posted from a computer, I see "
    Review has already been inserted from this computer. So no other reviews are allowed from this computer on this post."
    I would like to enable clients to reply to reviews from the same computer more than once.
    As of now, this wouldn't be possible
    Anybody know how to change this?
    Sorry...but you can post only one comment from a computer..
  3. rogerb
    rogerb Active Member
    I've also complained about this before as reviews should give the option for a reply.
    As far as I can see you can try several ways to work around this although only the third option is possibly viable:
    1. Change your computers IP address as this seems to form the basis of the check
    2. If you can't do that then go direct to the database with phpadmin and change the IP address for the review comment there.
    3. Request Inkthemes developers that this is an option that should be included as standard in the theme. I second this option and I'm sure many others would as well.
    Hope this helps
    Roger B
