Move menu
Discussion in 'BlackWell-WordPress Business Theme.' started by nirit1, Aug 17, 2014.
  1. nirit1
    nirit1 New Member
    1. Is it possible to move the menu as a top bar ?
    2. Is it possible (if 1 is not possible) is it possible to move the menu to the right side?
    3. Why is the demo uploading is slow ?
    4. Is it possible to reduce the size of the slider ?
    5. Is it possible to view both the menu and the whole page ?
    Thanks !
  2. Pramod
    Pramod Guest
    Unfortunately there isn't a way to do that with this theme unless you custom code something up. Sorry.
    You are advised to use StartPoint and Business Grow theme.
    Thanks & Regards​
    Pramod
