Moving page higher on background and where to change color
Discussion in 'Compass WordPress Theme' started by computerpros, Jan 7, 2016.
  1. computerpros
    computerpros Member
    For better viewing, I would like to move the webpage to the top of the colored background. Also, I would like to reduce the height of the Header box that contains the logo and the page navigation buttons. I have attached a pic to better explain.
    Also, what is the suggested image size for the logo?
    Also, how do I change the color of the background?
    Thank you for your help!
    Solutions of your above issues are accordingly..
    1) I would like to move the webpage to the top of the colored background.
    .page_content_wrapper {
        margin: 27px 0 120px 0;
    2) I would like to reduce the height of the Header box that contains the logo and the page navigation buttons.
    Code is given below,
    .header {
        margin: 13px 0px 4px 0px;
    3) what is the suggested image size for the logo?
    Suggested size is 340px*46px as you can also check it from theme option panel of your dashboard (under General Setting).
    4) How do I change the color of the background?
    body {
        background: lightsalmon;
    Note: Change numeric value and color as per your requirement..
  3. computerpros
    computerpros Member
    Are you sure this size is correct?? I have attached a screen shot, I don't see what the resolution is to be.
    Also, could you explain more about changing the color of the background? That is still unclear on where I get the number and where to put it in the CSS code. Thank you for the other settings, they worked pretty good!
    Sorry for the previous reply of the logo size....
    The size of logo is 170px*35px as you can also check this in the screenshot given below..
    For the background color, code is given below and also there is a screenshot where you have to put that CSS in your dashboard.
    body.compass_theme {
        background: lightcoral;
  5. computerpros
    computerpros Member
    Thank you for the reply. I understand "where" to the CSS code, but where is the colors that I can use? Is there a list of color options? For example maroon.
  6. priya
    There is an option for selecting color for your theme under styling option (Appearance=>Theme Option=>Styling Option=>Theme Stylesheet) of your dashboard as you can also check it in the screenshot given below.
    And if you want to add another color for your background, you can easily add that by adding the code (as I have also mentioned in my previous reply) and put your desired color instead of light coral, like:
        background: gray;
    Here I am giving you a site URL where you can find various color code, please have a look..
    http://html-color-codes.info/color-names/
    Hope you will find it helpful..
