Multi language pages
Discussion in 'BlackBird WordPress Theme' started by penz, Aug 19, 2013.
  1. penz
    penz New Member
    Hi!
    I'm using your template to build a multi language site. I was wondering which plug in would you recommend to do this. I usually use qTranslate but I would like to know which one would work best with the blackbird theme. Thanks in advance for your help.
    Diego
  2. penz
    penz New Member
    Anyone?
  3. Nitesh
    Sorry for the delay.
    You are already using correct plugin.
    qTranslate plugin work fine with "Blackbird theme".
  4. penz
    penz New Member
    Excelent! Thanks Nitesh!
