Multi language Plugin
Discussion in 'Woodpecker WordPress Business Theme' started by pratam1, Jan 25, 2016.
  1. pratam1
    pratam1 Member
    Have you install the plugin in your dashboard..?
    If no, please follow the screenshot given below to install the plugin first in your dashboard and then configure as per your requirement.
    hope you will get it helpful...
  3. pratam1
    pratam1 Member
    Hi Priyanka,
    Can you please do a search for it and highlighy which plugin i'm supposed to download?
    Sure...!!
    Below is the screenshot, please have a look..
