Nav Bar is overlapping another row of content. How to fix?
Discussion in 'RoadFighter WordPress Theme' started by gloryous, Aug 21, 2015.
  1. gloryous
    gloryous Member
    On pages other than the Home page, the nav bar overlaps the next row of text that indicates which page visitors are on. I either need:
    • the nav bar height to be less thick (less in height, with text still centered vertically) which might create the needed space; or
    • to have some space created below the nav bar so it doesn't overlap.
    http://demo77.digitalwordpower.com/ywca/
    Thank you,
    Glory
  2. nitin
    nitin Guest
    Hi Glory,
    .menu-wrapper {
          height: 42px !important;
    Note:- Please change the height accordingly.
    Nitin
  3. gloryous
    gloryous Member
    Hello, Nitin...thanks for your quick reply.
    Your CSS Code helped to resolve the height issue perfectly. Thank you.
    As I mentioned in the initial request, I need the text to still be centered vertically as well. The change in height has caused the second issue: the text to be off center vertically. It's now too low in the nav bar. Are you able to provide code that will resolve this as well?
    With appreciation,
    Glory
  4. nitin
    nitin Guest
    Everything is easy for us.
    #menu .ddsmoothmenu {
            margin-top: 9px !important;
    margin-left :0px !important;
    Note:- To fix the issue of text going too low in the bar, please change the 'margin-top' value and to center the text vertically please change the 'margin-left' value accordingly.
    Nitin
    gloryous likes this.
  5. gloryous
    gloryous Member
    Nitin,
    Thank you again!
    Glory
