Navigation Hover Color
Discussion in 'ColorWay WordPress Theme' started by 1stopnonprofitshop, Mar 31, 2016.
  1. 1stopnonprofitshop
    1stopnonprofitshop Guest
    Can I change the color when you hover over the navigation?
    #menu .ddsmoothmenu li a:hover {
        background: black;
    Note: Change the color as per your interest..
  3. 1stopnonprofitshop
    That worked. The only thing is the item on the navigation bar that is clicked stays purple...how do I change that color?
  5. 1stopnonprofitshop
    theme1.1stopnonprofitshop.com.
    I want to change the color on the navigation bar that is highlighted when you are on that page.
  6. priya
    For that, code is given below..
    #menu li.current_page_item a {
        background: red;
