Hello... I have installed the Appointway template and would like to use this... but the navigation when using IE is terrible. Whenever you move to a page the entire page moves and it is really annoying. see: http://jkliquidations.com/ (VIEW IN IE) The navigation is smooth in all other browsers... any ideas? Thanks Steve
Hello ! Please deactivate less required plugin if any. If still issue does not fix please download a fresh theme and install it. This will fix your issue. Thanks & Regards Pramod
Hello... I have deactivated ALL plugins and the issue still continues. The theme has been re-installed and the issue still continues. When the theme is viewed in "live preview mode" it works fine... it is only when I activate it that it starts jumping around in IE. We need this fixed and would be willing to pay for the necessary modifications!! Steve
Hello Steve, Please provide the following information listed below. This thread Link: Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] Thanks & Regards Pramod Patel
Hello ! I have checked your website and find that only in IE10 browser this animation issue occur all other version of IE works fine.. I am also little confused about this issue because on other sites this theme is working correctly. We will check it in detail and fixed this ASAP. Thanks & Regards pramod
