Need different background . ( Urgent )
Discussion in 'Covera WordPress Theme' started by sharful, Dec 26, 2013.
  1. sharful
    sharful Guest
    Hi, I need different background image for each and every slider with Parallax effect . If parallax effect not possible than please show me the criteria how i set different background for​
    slider .​
    Unfortunately there isn't a way to implement parallax effect in the slider of our theme unless you custom code something up. Sorry.
    But you can apply different background images for every slide.
    For this paste the code given below in Custom CSS section
    .slide.slide-1 {
    background: url('Enter the background image for first slide');
    .slide.slide-2 {
    background: url('Enter the background image for second slide');
    .slide.slide-3 {
    background: url('Enter the background image for third slide');
    .slide.slide-4 {
    background: url('Enter the background image for fourth slide');
    I hope this will fulfill your requirement.
  3. sharful
    sharful Guest
    Thanks a lot piyush .
