One of the core functions of any Google API map is the ability to input an address and see the nearest listings to that address. If you search for a location in Geocraft, it only applies a strict filter by city - it's essentially meaningless. Can you add the Google Maps function to filter listings by their distance from the location in the search bar? Also, if you add the GeoIP feature then the general search bar will show more relevant results, sorted by distance from the user's computer. It's a very handy feature (and crucial for my particular application).
I would like this too - very important, in fact essential as we move into ore and more mobile device usage.
I also need this. People are willing to drive 10 miles, shouldn't need for search results to match EXACT town name.
Hello, Greetings from InkThemes! Thanks for your precious suggestion. Could you please share any reference site so that we can discuss with our developers and try to implement in our next update for sure. Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
