NEED HELP - couple questions for home page
Discussion in 'ColorWay WordPress Theme' started by aaronwipip, Apr 10, 2018.
  1. aaronwipip
    aaronwipip New Member
    I am basically duplicating: http://www.usasurveyjob.com My website is www.usonlinejob.com
    On my website (usonlinejob.com) you can see under the offers it says AARON CODE HERE and Latest from the Blog. I need to know how to get rid of all that and fill the entire space with a Google Adsense code like he has. I have the code ready just need to kow where to go to modify that area. I found the area where it says Aaron code, but cant get the blog part off and have that entire section working. Please advise.
    Down in the third footer colum mine is blank, you can see he has rating widget in his.. I downloaded that and put it in, but mine doesnt show up. Please advise.
    Last but not least on my bottom footer you see I have 2 sections with text.. on his site he has one that goes across the entire bottom.. how do I get mine like his.. Thanks!
  2. akbar92
    Greeting from InkThemes,
    We need WordPress admin credentials to configure the required changes.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    And for the rating feature, I would like to recommend below-mentioned plugins.
    1. https://wordpress.org/plugins/wp-postratings/
    2. https://wordpress.org/plugins/multi-rating/
    Hope this helps...!
    Akbar
