"Need Help" feature to click through to my email address
Discussion in 'ButterBelly WordPress Theme' started by hixenbaugh9, Jan 24, 2014.
  1. hixenbaugh9
    hixenbaugh9 New Member
    Hi there,
    I've used firebug to look at the coding behind the "Need Help" feature and notice that the button does not point to any email address. Is there a way for me to get this button to send to my email address: [email protected]?
    Thanks in advance!
    That is the default form which is added just for the demo purpose.
    If you want to use same form, then go to the FormGet Website (Login from here: http://www.formget.com/ ) and
    create your form and then copy the embed code from there and paste it in the text widget of Home Page Sidebar Feature Widget Area.
    Or
    You can use any other widget in the Home Page Sidebar Feature Widget Area ( Dashborad > Appearance > Widget panel).
