Hi there. I'm having problems playing smil files using your JWplayer via url through the video uploads section of VideoCraft. The two following links describe how to compliment Wowza with JWplayer. When I play a stream i just get a black screen. https://www.wowza.com/docs/How-to-do-adaptive-bitrate-streaming#abr_vod https://www.wowza.com/docs/How-to-u...bitrate-streaming-from-Wowza-Streaming-Engine IT appears that VideoCraft is running JW-Player 6.7.4071, which satisfies the requirements for streaming SMIL files. Also, is there a way to provide adaptive bitrate transcoding with videocraft alone? Thanks
Hi, Greeting from InkThemes, It is impossible to implement adaptive bitrate transcoding with VideoCraft theme. Regards, Akbar InkThemes.com
