Hello I set up my site using clasicraft and customized it to our requirements. The site is http://ozydesi.com If u see it, you can see there is a Text just above the thumbnail scroller on Homepage which says " Search By Keyword & Zipcode "--I want to change it to "Featured Ads" and also I want to reduce the space between this line and the thumbnail scroll er. Could u pls help asap? Thank you very much
Hello, For reducing space Paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .search_wrapper h2 { margin-bottom: 9px; } change Keyword & Zipcode from your index.php or searchform.php where you write Keyword & Zipcode. Thanks & Regards Pramod
