Need help with dropdown menu.
Discussion in 'VideoCraft WordPress Theme' started by jimmygg, Dec 29, 2015.
  1. jimmygg
    jimmygg New Member
    Seeing as i changed some stuff around especially in the top_strip, theres a gap between the dropdown menu and the top_strip. Would love to adjust this but cant figure out what code to change. This includes the Small white/glowy border/effect on the drop down menu wich i would like to remove, so the design melts in better with the above parent menu.
    Thanks in advance
    JmyJi
  2. nitin
    nitin Guest
    Could you please provide us URL of your website, so that we can assist you accordingly?
    We would provide you a CSS code that you can implement in your website and get the things fixed.
    Looking forward to hear from you.
    Nitin
  3. jimmygg
    jimmygg New Member
    I am unable to access to your site as it redirects me to the login page.
    Kindly check..
  5. jimmygg
    jimmygg New Member
    Problem solved Pryia! Sorry for that.
  6. priya
    Hope doing good.
    I really appreciate your efforts in exploring the things.
    It seems that you have resolved your issue by your own.
    Let me know if have further doubts so that I can assist you.
